What Connector is this?
Old Mar 26, 2012 | 10:38 PM
Irocz_89's Avatar
Car: 1989 Iroc-Z Camaro: Sold :(
Transmission: Built 700r4
I'm getting no voltage to my Injectors after I took my steering column down and after I hooked it back up... It wouldn't start, so I took it back down to see if there were any connectors or wires I didn't connect back.
There was this connector that was unplugged which I don't know what it goes to because I don't see a female ended connection for it.
I posted a picture of the connector and a close up of it.
Attached Thumbnails What Connector is this?-4.jpg   What Connector is this?-2.jpg
Old Mar 26, 2012 | 10:39 PM
Irocz_89's Avatar
Re: What Connector is this?
There is also this Pink & Black wire, which looks like someone extended it which I don't know what it goes too... But its long enough that it can reach all the way to the Fuse Box, maybe that's something?
Old Mar 26, 2012 | 10:41 PM
Irocz_89's Avatar
... and also this looks like it needs a connector but I don't think it would have anything to do with the injectors...
It's actually the Cruise Control Connector (you can see the vacuum hose that disengages it by the brake pedal)
So... does this actually need to be hooked up for my car to start?
Because right now, I have no voltage and no pulse from my injectors.
Old Mar 26, 2012 | 10:43 PM
Irocz_89's Avatar
There are also 2 Black wires that I found on the ground, both of them 6 inches in length with a Male Ended terminal on it and nothing on the other ends of them (Like someone was going to twist splice them together or something.
Old Mar 26, 2012 | 10:45 PM
Irocz_89's Avatar
But all in all... My car hasn't started up since I took the steering column down to adjust my dimmer switch. Help Please?
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
