voltage drop
Old Apr 1, 2012 | 05:04 PM
petrolhead's Avatar
Car: '83 trans am Lear Siegler
voltage drop
I have a weird voltage drop when I give it almost half throttle, the battery voltage drops to 12. As soon as I let off, it returns to normal. It's not anything to do with the motion of the car, it will do it in park too. I've checked the wiring to the alt, everything looks good, any ideas?
Old Apr 10, 2012 | 11:29 PM
fbodyluver's Avatar
Re: voltage drop
You may have already found the problem (since this thread is 8 days old) but it sounds like your belt is loose.
Old Apr 10, 2012 | 11:49 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: voltage drop
could check the battery cables to see they have a loose
connection or other fault affected by movement of the
engine,or could be an internal fault in the alternator
such as out of round slip rings,worn brushes,broken
connection in the rotor,ETC.
Old Apr 11, 2012 | 10:19 AM
petrolhead's Avatar
Re: voltage drop
I haven't found the problem yet, the belt is tight, its just a certain amount of throttle movement that causes it, at any engine speed or driving condition.
Old Apr 11, 2012 | 11:28 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: voltage drop
Is it causing a driveability issue? Have you verified the volt drop at the batt terminals with a DMM, maybe it's just the gauge that's dicky for w/ever reason.
Old Apr 11, 2012 | 02:21 PM
petrolhead's Avatar
Re: voltage drop
It's not a drivability issue, I just know its not right, I haven't tried it with a volt meter, but the ecm is seeing the drop, it showdown up on the data stream.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
