Fuel Pump Relay Wiring
Old Apr 2, 2012 | 04:38 PM
formula_355's Avatar
Hi guys, i am in the middle of building a carburated 383 for my 89 Firebird Formula. I removed the ecm and the un needed wiring. then i realized i accidentally cut some of the wires for my fuel pump. What do i need to do to get the fuel pump to run without the computer. I read that the Green/white wire needs to be hooked to an ign power source, the black/white goes to ground, the tan/white goes to the other tan/white wire. But where does the orange wire go to?
Old Apr 2, 2012 | 05:00 PM
Re: Fuel Pump Relay Wiring
Also, if i removed my computer do i need to do anything with the vss/bufferbox to get it to work right?
Old Apr 2, 2012 | 06:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by formula_355
I removed the un needed wiring. then i realized i accidentally cut some of the wires for my fuel pump.
That is why you don't cut anything ; you just hide the old harness out of the way in case it is re-needed
To the battery
Old Apr 2, 2012 | 07:34 PM
ttrumbull56's Avatar
i had to replace my fuel pump today so i made i trap drop above the tank. i have the fuel assembly out and everything and i replaced the fuel pump. so i connected it to the wiring harness just to make sure thier were no electrical problems, but there is an electrical problem cause the fuel pump doesnt make any noise, to make sure the fuel pump was connected right i connected the wiring from the fuel pump to a battery just sitting in my garage and the fuel pump works by doing that. could it have somthing to do with have a bad carbuerator?
Old Apr 2, 2012 | 08:11 PM
sorry i forgot to mention, its an 84 camaro
Old Apr 2, 2012 | 09:21 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
i connected the wiring from the fuel pump to a battery and the fuel pump works by doing that.
Obviously you have no power to the pump
checked the fuse?
Old Apr 2, 2012 | 09:24 PM
the fuse was fine, the relay wiring maybe?
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Kaweh
Aug 9, 2015 02:54 PM
