wire that powers interior lights/door locks/head lights
Old Apr 9, 2012 | 01:12 AM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Hi
Need help identifying wire that powers the headlights, interior lights, power locks/mirrors, cigarette lighter and hatch pull down.
I have tracked it down to a loose connection under the dash, When I move the wiring harness that goes to the fuse panel the interior lights go on and off with door open. When off none of the above work.
There are several wires as this is where two main harnesses go through the firewall. Not sure if both go to fuse box. If I can confirm wire color and location I can look for defect in that wire. With some many in that area it is tough to narrow it down. Any help would be appreciated. Thanks
BRoss99
Aug 10, 2025 05:08 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
