some electrical issues
Old Apr 9, 2012 | 07:03 AM
SanAntonio3's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
I recently swapped my engine bay wiring harness and under dash wiring harness, and some issues have came up. The engine bay harness is from a 90 model firebird this, and the dash wiring is from a Camaro... unsure about the year.
Symptoms : when I hit 60 MPH and hit on the brakes slightly the engine light turns on. It never did that before I swapped wiring. And when I connect the Soluspro diagnostic computer it can not communicate with the ecm whatsoever. It use to do that as well.
What could I have forgotten to connect in order to check the codes? Something behind the dash not connected?
Old Apr 9, 2012 | 07:17 AM
Re: some electrical issues
Also forgot to mention that my wipers don't work now. Fuse is good, will cycle throught low and high, with no movement from wiper motor...then when I hit the windshield washer fluid it blows the fuse. What gives?
Old Apr 9, 2012 | 10:41 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Sounds like the haness you have isnt compatible with the dash harness. What year is the dash harness as I know 90 to 92 engine harnesses are different from other years and the C100 pinout is different
Cornholio7979
Sep 20, 2018 02:31 AM
Gambit TA
Sep 1, 2015 07:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
