Code 12- Bad computer?
Old Apr 9, 2012 | 12:49 PM
12gauge's Avatar
Car: 89 Trans Am
Engine: 305 V8 TPI
Transmission: 700R
Axle/Gears: 308 Eaton Posi
Hey all,
My '89 305 T/A randomly shut down on me the other day while driving. Upon trying to start it up, it turns over but doesn't ignite. I can smell fuel, so lack of fuel is not the issue, but I'm getting as constant error code 12 (even after the initial 3 times it flashes). What does it mean "no reference pulse to the ECM"? Does this mean I need to replace the ECM, or something else? Please help! Thanks!
Old Apr 12, 2012 | 05:29 PM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
Re: Code 12- Bad computer?
When you pull codes from the ecm they repeat. So if your getting only code 12,the computer has no trouble codes stored.
It takes fuel and spark to start, so check that your getting fuel at the engine. You could be smelling fuel because of a leak somewhere, tank, damaged line, fuel filter, etc. Check for spark too. When your engine died, did it immediately stop or kinda sputter to a stop like if you ran outta gas?
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Bryan F
Aug 18, 2015 02:28 PM
apie2546
Aug 10, 2015 05:43 PM
