Wiring Woes
Old Apr 17, 2012 | 07:30 AM
Vikemaro's Avatar
Wiring Woes
'87 IROC, going through electrical system. All gauges work but tach and oil pressure, and all lights work but front turn signals, front side markers, dash lights. All fuses and relays check out ok. Oh, and those front turn signals, the parking lights work, but do not flash while rear do. One more thing, when turn on high beams, the low beams go out. smh
Old Apr 17, 2012 | 07:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Wiring Woes
tach and oil get their readings straight from the sensors (back of intake and distributor). have you checked to see that the wiring to them is solid? harness goes to C100 on the driver side firewall
Old Apr 19, 2012 | 09:39 AM
Vikemaro's Avatar
Re: Wiring Woes
previous owner cut several wires in loom, i tried jumper from those wires to the tach plug in on dist., and to o.p. sender on block, but to no avail. smh
Old Apr 23, 2012 | 05:48 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash Distress
Originally Posted by Vikemaro
……i tried jumper from …… o.p. sender on block, but to no avail.
At the back of the dash on one of the two connectors you will see a tan wire.
Disconnect it, turn the key to RUN, and observe the OP gage.
What did it do?
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Old Apr 28, 2012 | 12:08 PM
Vikemaro's Avatar
Re: Dash Distress
Forgive my ignorance, but disconnect the wire? I don't follow you. Do you mean pull the tan wire from the connector, or leave the connector unplugged from the gauge cluster? smh
Old Apr 30, 2012 | 05:22 PM
NINÅ's Avatar
Transmission: 765R4
Dash Distress
You just want to disconnect that one wire.
Most likely the fastest way will be to cut the wire in an area you will be able to get your hands into, to splice it once the diagnosis is made.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
