speedometer reading too high 1992RS
Old Apr 17, 2012 | 03:09 PM
Alex1992RS's Avatar
I just bought this car so I dont know the history Speedometer reads maybe 10 MPH too High, looking at the board I see fixes for this problem by changing the gears for the sensor in the tailshaft and I see a fix by programming, which is the way to go. I feel maybe the tranny has been changed in the past but I dont know for sure. I also dont think this problem is linear that is the faster you go the more wrong the speedometer is off.
Old Apr 17, 2012 | 06:39 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: speedometer reading too high 1992RS
What size tires are you running?
Old May 10, 2012 | 11:11 AM
Alex1992RS's Avatar
P235 R55 16
Old May 10, 2012 | 01:19 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Have your local tyranny shop do a free inspection and tell you your rear gear ratio. Compare that yo your original ratio. Also have the see if the tyranny is original or not. I would myself prefer to change the gear in the transmission in conjunction with tires to correct the problem.
toones
Jan 6, 2016 06:00 PM
AUZ28
Oct 12, 2015 08:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
