82 z28 Tach
Old Apr 18, 2012 | 01:35 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
82 z28 Tach
i have a problem with the tach. its not reading and i took pics of wiring at cap and the wires are back in the correct place need help thanks
Old Apr 19, 2012 | 07:43 AM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: 82 z28 Tach
Any help would really be appreciated
Old Apr 23, 2012 | 05:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tach Talk
Using a test bulb (a side marker bulb works well) connect one end to the white wire going into the dash from the distributor, and the other end to ground.
When the engine is idleing does the bulb pulse?
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Old Apr 24, 2012 | 12:52 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: Tach Talk
Happy Racing!
thanks ill check that out
Old Apr 25, 2012 | 03:55 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: Tach Talk
Happy Racing!
so i used a test light and check the wire from the coil and i get power but then when it goes up to the tach filter and comes back around, it doesnt have power other the otherside. I never removed the tach filter so the ground isnt bad but i cant even find a replacement for it online anywhere
Old Apr 25, 2012 | 04:12 PM
NINÅ's Avatar
Transmission: 765R4
Tach Talk
You can get a tach filter from GlowShiftDirect.com
Happy Racing!
Old Apr 25, 2012 | 04:31 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: Tach Talk
Happy Racing!
ok thanks ill check that out
Old Apr 25, 2012 | 04:33 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: 82 z28 Tach
not the same one. mines got one wire going in and one coming out.
Old Apr 30, 2012 | 02:55 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: 82 z28 Tach
i cant even keep the car running long enough to even atempt to set the timing. this time i started it and it held to the ecm but then back fired out of a throttle body and died. the rest of the times it loses connection to the ecm and the rpms just start rising.
Old Apr 30, 2012 | 05:34 PM
NINÅ's Avatar
Transmission: 765R4
Filter Frustration
The aforementioned filter costs only $9.
You should be able to find the wire which will give a passthru of the filter.
RockAuto.com has them for $16 which they call a ‘wire’ so check that out to make sure the filter is on that wire.
Corvette Central has the direct replacement for $55.
I don’t have time to address the stalling problem, hopefully someone will chime in.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Sep 20, 2015 11:36 AM
Racerx974
Sep 19, 2015 10:16 AM
TrevinE
Sep 14, 2015 03:20 PM
