Hazards not blinking
Old Apr 27, 2012 | 08:17 PM
travisgold's Avatar
Car: 1984 Camaro Z28
My signals work but my hazards don't. when I put my hazards on the side markers, the tail, the signal indicators, and the front lamps lightup
even thought the signal indicators light up they don't blink, and the lights don't blink,
at first i had no hazards at all, when i pressed the button nothing would happen but my turn signals still worked, so i looked in my fuse center, there was no fuse connected just a wire running into where the fuse was suppose to be, so i unplugged the wire and connected a 20a fuse.
Old Apr 27, 2012 | 09:57 PM
travisgold's Avatar
Re: Hazards not blinking
anyone?
Old Apr 27, 2012 | 10:20 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
The flashers on my 84 SC is just under the dash on the drivers side beside the counsel, There are 2 of them right around there, one for the signals and one for the emergency flashers. I would start there.
Mark.
Old Apr 27, 2012 | 10:51 PM
travisgold's Avatar
thank you, another problem is when the hazard fuse is in the brake lights stay luminated.
Old Apr 28, 2012 | 06:49 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
As whatever posted start with the hazard lights flasher.
Old Apr 28, 2012 | 12:27 PM
travisgold's Avatar
thank you, im going to go start work on it in about 15 mins.
Old Apr 30, 2012 | 05:08 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
DANGER ! · · · · · · Hazardous Information
A defective hazard flasher cannot cause the brake lights to illuminate.
After you check the flasher, check the brake light switch for a non-opening contact.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Apr 30, 2012 | 05:22 PM
travisgold's Avatar
Re: DANGER ! · · · · · · Hazardous Information
Happy Racing!
could you explain to me where to find the hazard relay, i removed two relays, a green one and a grey one from under the dash, it did nothing when i removed them, the signals still worked..... i know the hazard fuse also controls the brake lights, but even without that fuse in the brake lights work, my third brake lamp however does not work. at all.
Old Apr 30, 2012 | 05:56 PM
travisgold's Avatar
Happy Racing!
okay nevermind i was looking under the panel and found out that blue wire i was talking about earlier connects to a orange wire that is connected to the brake switch, there is another orange wire aswell that has been connected, so originally the two oranges connected. I am going to reconnect the two orange wires and see what happens
Old Apr 30, 2012 | 06:18 PM
travisgold's Avatar
well me connecting those two wires didn't do a thing... ugh
Old Apr 30, 2012 | 06:40 PM
Edwardgp's Avatar
Engine: 454-350
As NINA posted now you need to see if that brake light switch shuts the power off to the brake lights when peddle is up.
Old Apr 30, 2012 | 06:42 PM
travisgold's Avatar
it doesn't seem to
Old Apr 30, 2012 | 06:48 PM
Edwardgp's Avatar
Engine: 454-350
This would be a good place for you to have a test light. If you can remove one wire and see if the brake lights go out with peddle up you probably found the problem. Sometimes that switch just needs to be adjusted. Get under there and take some time checking things out.
Old Apr 30, 2012 | 06:58 PM
travisgold's Avatar
which wire should i remove? there is already a wire cut there anyways.
Old Apr 30, 2012 | 08:00 PM
Edwardgp's Avatar
Engine: 454-350
It dose not mater just so you can put it back together.
Old Apr 30, 2012 | 08:07 PM
travisgold's Avatar
well it didn't do anything still the same scenario, i looked the at fuse box the owner had miss matched fuses everywhere, 20 amp in 10amp, 10 in 20 amp slot, most of them were upside down. I also discovered I have no reverse lamps either.
Old Apr 30, 2012 | 08:28 PM
travisgold's Avatar
Okay so this is the current situation im dealing with, No Hazards, No Reverse lights no matter what, the turn signals are all fine, the fuses and not blown, the switches are fun, I have to check and see if the reverse lights are burnt out
Twin_Turbo
Mar 14, 2016 10:10 PM
Jk_Under
Sep 2, 2015 10:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
phisherness
Nov 26, 2001 10:36 PM
loc0bob
Jun 3, 2001 12:27 AM
