dakota digital sgi-5 fix speedo?
Old Apr 18, 2012 | 03:41 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
hello to all!
i recently installed a 3.42 posi in my firebird.
and can not find the drive and driven gears anywhere!
Talked to a buddy and he said to try dakota digital sgi-5
my vehicle has been swapped to a tpi from a tbi and im stilling using the speed buffer for the tpi setup
so any comments would be nice! thanks
Old Apr 18, 2012 | 04:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: dakota digital sgi-5 fix speedo?
You might have too call the. Looks like application 3 would work not 100% positive because it does not state the lower 2kppm input you are using. It does have a 2k output that could goto c6 on your (Since someone reprogramed your memcal to optical vss) 730 ecm and than the output of b11 could feed your speedometer the buffer would go into file 13. Hopefully MR RBOB will chime in.
Old Apr 18, 2012 | 04:17 PM
Engine: Lb9
Transmission: M20
http://static.summitracing.com/globa.../dak-sgi-5.pdf
Old Apr 18, 2012 | 04:45 PM
dabird07's Avatar
Car: 92 firebird
Originally Posted by tunedperformanc
(Since someone reprogramed your memcal to optical vss) .
wonder who that was. . . .
lol
thanks tune i havent found time to researh so id figure i would ask tgo for input .
hope this thread doesnt end up looking like my last with a 100+ post and 1900 + views ?! hahahaha
thanks again ,
dabird07
Old Apr 18, 2012 | 04:52 PM
Engine: Lb9
Transmission: M20
I know nothing
Old Apr 20, 2012 | 01:15 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/engi...igita-sgi.html
GTAman
Jul 3, 2024 07:29 PM
MantyZ28
Nov 8, 2015 06:54 PM
TrevinE
Sep 14, 2015 03:20 PM
earlpote
Sep 12, 2015 11:55 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
