No Power Mirriors, Door Locks, horn or inirior lights.
Old Apr 23, 2012 | 01:08 AM
02 camaro's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 305 T.P.I V-8
Transmission: M5
Axle/Gears: 372's
I Just bought a 1992 Z28 Heritage Edition, The Trunk pop, Power Mirriors, Power door locks, Cig. Lighter, horn or dome lights dont work. My Passenger side window works Driver does not(Motor is bad) and all my gauges work fine. My old 1987 Formula had this same issue. Never could figure it out. I think it is common any ideas thanks or any one know what it is that would be a TON of help!
Old Apr 23, 2012 | 01:26 AM
djjon76's Avatar
Car: '84 Trans Am
Re: No Power Mirriors, Door Locks, horn or inirior lights.
When this happened on my '84 T/A, it was just one fuse I had to replace and everything came back to life!
So I'd start at the fuse block. I can't remember what it was called, but check each one.
Old Apr 26, 2012 | 07:13 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
Ive checked all fuses 5 times! Not the fuse. Is there a common wire that comes loose under the dash some where. Not a big deal it would be nice to have all my power stuff back.
Old Apr 28, 2012 | 12:46 AM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
Anyone have this problem?
Old Apr 28, 2012 | 01:17 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That problem is almost always the ACC fuse as all of those loads are supplied by it. The normal culprit is a short in the cigarette lighter. Don't just visually check the fuses as they can look OK but still be open. Check fuses with a meter or test light. If fuse is good, then I might check fusible links.
Old Apr 29, 2012 | 12:56 AM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
Yup I think i got the Idiot of the year award! I didnt now what spot the power stuff went too. Turned out the fuse was missing. Wela they all work now. Thanks guys.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
