Bypassing VATS Question #2
Old Apr 25, 2012 | 01:11 PM
Irocz_89's Avatar
Car: 1989 Iroc-Z Camaro: Sold :(
Transmission: Built 700r4
Okay so I bought the Bypass Vat Module and I STILL got no start from it...
I "THINK" I hooked everything up correct...
I took the "Red 12v ignition wire" and opened(not cut, open, just removed the protective coating on the wire) a wire from one courtesy lights and twisted the red 12v ignition wire onto it.
I then opened the Dark Blue wire that is on the ECM connector B6 and twisted the "White: Fuel enable wire. 50hz or 30hz" wire onto that one.
I then first took both the Control wire and Ground wire and grounded them out together (30hz signal) to test it.... Still Crank No Start...
.... Then I unhooked the Control wire from the Ground wire and just grounded the Ground wire and still... Crank No Start.
The LED Light is coming on telling me that I hooked everything up right.
My question is... When hooking up the "Control Wire," am I supposed to Cut open the Dark Blue and then just splice the control wire to it.... or what?
Old Apr 25, 2012 | 02:33 PM
Irocz_89's Avatar
Re: Bypassing VATS Question #2
Okay, another question...
Do I cut the B6 wire on the ECM when hooking up the Fuel enable wire?
Old Apr 25, 2012 | 03:11 PM
Irocz_89's Avatar
I'm just going to by a prom from TPIparts.net with VATS disabled since nothing I seem to try works.
Old Apr 26, 2012 | 06:09 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Why are you bypassing it anyways broken wire in column?
Old Apr 26, 2012 | 10:21 AM
Irocz_89's Avatar
Because my injectors aren't firing. I'm getting Fuel Pressure, Spark & and Compression.
But my injectors aren't firing... & the only way we got the car running before was by purchasing an Eprom w/ VATS disabled. But I don't have that Eprom anymore & now my car isn't starting.
Old Apr 26, 2012 | 04:15 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
That was a problem I had also. I bought a VATS bypass module and no start. I bought a different brand and still no start. I did try both 30 and 50 hertz signals also.
I ended up putting a carb on my V6 but am planning a swap to V8 now with a 91 TPI setup so will need to buy a VATS delete chip.
I never did find out why the bypass modules did not work.
Glowsock
Jul 24, 2025 03:15 PM
stalkier
Dec 6, 2015 11:25 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
