Need quick coil answers
Old Apr 28, 2012 | 06:49 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
Hey guys, just got the camaro legal.... I know my tach is wrong, so I'm hooking an aftermarket one up.... When I look through my Haynes manual it says the white wire is the negative, correct? But there are two going to the coil, so which would I hook the tach to? Thanks, 91 305 tbi
Old Apr 30, 2012 | 05:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tach Talk
The White wire you need to use comes from the ignition coil primary.
I don’t know what Haynes means by “
white wire is the negative”, due to the fact the wire you need is POSITIVE.
Hopefully the PO didn’t change any wire
colors.
You can find out if the
White wire is correct by using a small bulb such as a side marker lamp to probe the White wire.
If it’s the wire for the tach it will pulse when the engine is idling.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
corey8084
Sep 17, 2015 02:56 PM
mackjar66
Sep 14, 2015 01:17 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Jlanz55
Sep 6, 2015 03:05 PM
