Radio goes off and then back on
Old Apr 30, 2012 | 07:11 PM
larryz28's Avatar
Car: 82 Z28
I have an 82 Z28 with a lot of mods not much left that is stock.Last year my alternator went out and I had it rebuilt. But at the same time my radio which is not stock started to turn off and then back on. Also if the radio is playing and I pull out the light switch, the radio goes off and then back on. I have tries everything I know. I wired the radio up to the battery, I have changed the headlight switch twice. I switched radios and nothing changes. I do not know much about alternators but could it have been rebuilt wrong? The car starts find. I did put a meter on the wire to the radio and it was showing 12.5 volts, but when I pulled out the light switch it dropped to 10 volts. Any thoughts would be great thanks..
Old May 2, 2012 | 06:47 PM
red88tagta's Avatar
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Re: Radio goes off and then back on
Sounds like a bad connection in the wiring that feeds the car wiring system, either from the battery terminals or at the starter.
Old May 3, 2012 | 09:46 AM
larryz28's Avatar
Car: 82 Z28
Thanks for your thoughts, I think then was something going on with the groud wire.. works much better now, thanks again..
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
arod231
Aug 16, 2015 02:51 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
