Dash Lights and shifter lights wont come on when driving
Old May 3, 2012 | 12:29 PM
GMC_Jimmy13's Avatar
Car: 92 Camaro 25th anniversary
Ok so when i turn the key the check engine light will show but when the car is started none of the dash lights of the shifter lights will be on. Head lights work, radio works, dome lights work, pretty much everything except dash and shifter lights. Checked fuses dont see anything burned out there.
This is a pain to drive at night, I cant see how fast im going! any ideas?
Old May 14, 2012 | 01:54 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Indicator Info
You can test the dash portion of the SHIFT light by grounding, thru a 1 amp fuse, pin F of the “scanner” connector located under the dash.
If the bulb and associated connections are good the bulb will illuminate.
To diagnose the dash illumination lights make sure the dash dimmer control is set at the bright position, then using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe both sides of the INST LPS fuse.
If there is no power there check for power on the
orange wire at the headlight switch.
Then check for power on the
dark green wire at the headlight switch.
Is there power on both wires?
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Omega
Aug 10, 2015 12:46 PM
