Gta digital dash swap
Old May 6, 2012 | 04:33 PM
KARR44's Avatar
Car: 89 firebird
Engine: 5.7 l
Would a gta digital dash work in a 89 formula?
Old May 21, 2012 | 12:10 PM
SLZ's Avatar
SLZ
Re: Gta digital dash swap
A digital dash from a 1987-88 T/A, GTA would physically fit an 89 Formula 350 (since I already accomplished this). However.......it is NOT a simple cluster swap. You would need an entire digital dash assembly (frame, wiring etc...) out of an 87-88 Digital Dash car to start with since the wiring for digital is different than the analog. I ended up stripping the old DD assembly of all its specific wiring, parts and piggy backed it onto my analog dash system. This way, if I wanted to swap back to my analog cluster for any reason, I could just fish out my analog connector from the back of the dash and now, its plug and play. Mind you, this took a lot of research to do this conversion this way (using 1987 and 1989 Firebird shop manuals, an electrical background and Patience, so it is not for the faint of heart).
Old Aug 3, 2012 | 04:07 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
so. how crazy would it be to want to swap an gta digi dash into an 84 camaro, and i already think i'll have to swap the whole harness and dash and cluster and all, or if i were planning to swap to power windows and locks could i swap the whole cabin harness from the firewall back out of an 87-88 gta, also i do plan on swapping the car to a tpi engine, also i know how insane this sounds
Old Aug 3, 2012 | 07:30 AM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
IMHO, having a GTA with a factory digital dash myself and reading numerous posts of what other do to install one, I would say either stick with what you have or get another car with what you want.
Old Nov 26, 2012 | 12:35 PM
JAYBIRDPHEONIX's Avatar
Car: 1987 FIREBIRD
Engine: 305 CARB (FOR NOW)
Transmission: WC BORG WARNER T5
Axle/Gears: 327 posi disc
I was thinking of doing the same swap.....what did you end up doing? I have an entire parts car with the digital dash and everything and was playing with the idea myself...not sure if thats how im gonna go
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Street Lethal
Aug 14, 2015 08:25 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
