sensor questions for mods
Car: 1988 T/A Hatchback
Engine: 5.0 TBI soon to be carbed
Axle/Gears: 10 bolt 3:73 not sure on the gearin
I am wondering how to bypass some sensors, like the knock sensor because I am wanting to put timing gears instead of the timing chain, the A.I.R. pump i want to get ride of and install headers, what sensors can I get rid of or bypass and still have it pass inspection. Also wanting to completely get rid of the A/C unit to unclutter the engine compartment. Would this be advisable?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: sensor questions for mods
Why?
Engine sensors are there for a reason ;
Knock sensor for example stops your engine blowing up
Most relate to engine operation, delete them and your engine wont run right
Depends what your state requirements are; some will defect you just for removing stuff
AIR and Ac you just unbolt and install delete pulleys in their place
I live in NC. If the older cars (before computer vehicles) didn't have them, then why would it cause the car to "blow up"? Talked to a fellow at a recent car show and he told me, he unplugged his and it runs fine. Then how do they beef up cars (some radically) or even do engine swaps and by pass the pc's?
if you don't want all the sensors, just pull the harness and convert to carb. FI is designed to run with all its sensors in place, most new cars have far more sensors than ours do. While you can unplug certain sensors and have the car run, it does not mean it will run well. As far as passing tests and removing emissions equipment usually you have to find someone to look the other way
I will check into that. A friend suggested that also, would love to add a tunnel ram on it w/ 2 fours.
Car: 82 Z28
Transmission: T400
No or wrong info and the computer doesn't know what is going on.
In the case of the KS it looks for engine knock; if it sees it it retards the timing to stop it happening.
Google engine knock or pinging to see what it does to a engine
http://www.facebook.com/pages/Pingin...11402852220839
Only way to "bypass" the computer is as noted above ,is to fit a carb
Transmission: 5-speed/T-5
Yes I am going to do the sway! American Auto Wiring has the wiring harnesses for these sways.
