Electrical help blinkers and tail lights
Old May 14, 2012 | 04:11 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
A few days ago I noticed that my blink was only flashing part of the time. Now when I use my blinkers the front bulbs light up but very dim. While checking my blinker problem I noticed my tail lights, rear blinker, reverse light, and tag light all stop working when my blinkers don't work properly. Sometimes though my blinkers work right and so do my tail lights but then it will randomly stop. I have checked my ground and have power coming into light sockets yet my bulbs work randomly. Any Ideas??
Old May 28, 2012 | 03:00 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
Re: Electrical help blinkers and tail lights
Update: I got my blinkers to work when my head lights are off, but my entire rear light assembly flashes. When my headlights are on none of my rear lights work at all. Any help would be great.
Old May 29, 2012 | 04:59 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Lights Without Might
First check the ground(s) at the taillights assembly.
Your
*UPDATE* problem is consistent with an open ground.
Then check the taillights connector located at the left rear corner of the body.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old May 29, 2012 | 06:50 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
I have checked my grounds on my rear tail lights and have a good connection. Any other place I should check?
Old May 29, 2012 | 07:04 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Your battery ground to frame, your head light grounds, your engine ground to firewall, and any other ground you find. Take them apart sand all surfaces put them back together tightly and paint them.
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
