Need Help no power at the crank fuse??
Old May 15, 2012 | 07:45 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Axle/Gears: G92 3:23
hey guys i got a 91 z28 i got no power at the crank fuse/and starter so no cranking action nothing??, its got new neutral safety switch and starter relay and ignition switch, computer and theft deterent module along with a new key tumbler/new key.. im lost Help
Old May 21, 2012 | 04:02 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Crank Call
The CRK fuse should have power with the key in the START position.
The
CRK fuse is there to protect other parts, a dead fuse will not prevent cranking.
The fact your
CRK fuse has no power is a symptom, not a cause.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the yellow wire at the starter enable relay, which is located under the left kick panel.
Is there power there when you try to start the car?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old May 21, 2012 | 04:18 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Re: Need Help no power at the crank fuse??
Ok the stater enable relay using a power prob im getting 6v but should 12 v correct when i apply 12v car cranks
Old May 29, 2012 | 04:36 PM
NINÅ's Avatar
Transmission: 765R4
Crank Call
Yes there should be 12 volts there.
Now we need to find out where that 6 volt drop is originating.
While trying to crank, measure the output on the
10 gage yellow wire at the steering column connector.
If it’s 12 volts, the 6 volt loss if between that point and the input on the Enable Relay.
If it’s 6 volts, measure on the
10 gage red wire at the same connector the 10 gage yellow wire is.
If it’s 12 volts, the 6 volt loss is in the ignition switch, or the actual connection going to it.
If it’s 6 volts, the loss is between that point and the battery.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
formula_novice
Sep 5, 2015 03:58 AM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 13, 2015 12:59 PM
