brake lights wont come on when slowly depressing pedal
Old May 20, 2012 | 10:15 PM
Spike_Akers's Avatar
Car: 83 camaro z28, 92 xj
Engine: 305 Crossfire (lu5)
Axle/Gears: richmond gear 3.73:1
my 84's brake lights wont come on when you ease the pedal down but will come on when you stomp the pedal, would this be a problem with the switch or wiring somehwere?
Old May 20, 2012 | 10:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: brake lights wont come on when slowly depressing pedal
Most likely your old worn out brake switch on the brake pedal is sticking and needs the heavy tap to make it work
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Aug 5, 2015 07:57 PM
