1984 Wiper Motor Wiring
Old May 23, 2012 | 05:06 PM
Sled_Dog's Avatar
We have a 1984 Berlinetta in the shop right now that I am trying to get the wipers up and running on. This car was gutted to be a race only car, now this customer wants it back on the street. We had to replace the multifunction switch assembly(Turn signals, wipers, and various other pieces). Finding a switch for this 1984 apparently was not possible(discontinued) so a switch for a 1982 was installed. That is a headache of wiring changes, but I can handle that.
My issue is I cannot seem to energize the motor and make it function so I can figure out the wiring. None of the All-Data wiring diagrams seem to match up properly. The car didn't have a wiper motor when I got to it, so we got a junkyard unit(reman didn't have the pump/cover assembly). The junkyard unit(and the reman) both have 2 wire plugs at the bottom of the motor, and 3 wire plugs up at the cover area. I cannot locate any connector to go to the 2 wire connector at the bottom of the wiper motor, and absolutely NO reference to this connector in All-Data.
I may well have to wire this motor from scratch or have the wrong wiper motor. Is anyone familiar with what I am talking about?
I am sorry to start a new thread when I found so many wiper motor threads, but none seemed to refer to the unique wiring situation I seem to be in. Some mentioned the connector at the bottom, but no reference to its function, wiring colors, or pointing to it in a diagram.
Thanks in advance.
Old May 29, 2012 | 04:40 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wire Mire
The washer activation is the pink wire.
The main power activation is the
purple wire.
The delay line is the
orange wire.
The delay disable line is the
gray wire.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
mhatfield 14
Aug 15, 2015 10:47 AM
slade5612
Aug 11, 2015 07:19 PM
