where can i hook up an aftermarket fuel gauge
Old May 24, 2012 | 02:44 PM
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
i know my stock fuel gauge is bad. i want to tap into a wire so i can run an aftermarket guage. anyone know a convienient place to splice. i dont want to take my dash apart or splice where the fuel pump wires go thru the back seat area. there are wires running under my console and behind the radio/a/c controls. i just dont know which to tap into.
88 trans am automatic.
Old May 24, 2012 | 07:44 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: where can i hook up an aftermarket fuel gauge
Sure the gauge it self is at fault?
Sender unit in tank usually gives problems 1st.
Make sure the sender is working before installing a aftermarket gauge that uses the same ,possibly faulty sender input
Old May 28, 2012 | 01:37 PM
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
is there a convienent place to check with an ohm meter? i know the sender is like a mechanical resister and the fuel gauge is like an ohm meter
Old May 29, 2012 | 04:43 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tap Dancing
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
It’s the same
purple wire referenced below* you will use if you decide to add a new gage.
Tape the removed sender wire so it can’t short.
Connect a 47Ω resistor to the gage where you removed the sender wire.
Connect the other end of the resistor to ground.
Turn the key to RUN.
If the gage is good it will read about ½ way.
So, if the gage is good, you know the problem is the sender or the wiring going to it.
*Behind the dash on the left side of the car there is a connector.
Cut the
purple wire (but leave enuff to resplice in case you cut the wrong one) and connect that wire to your new gage.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Dec 30, 2014 | 09:14 AM
0078red1's Avatar
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
do i look for the sender wire in the back of the car or under dash?? new to this wiring things
Old Jan 2, 2015 | 02:08 PM
NINÅ's Avatar
Transmission: 765R4
Sending Information
The sender wire (purple wire) travels from the connector located behind the left rear seat to the back of the dash.
Wherever you tap into it or reroute it is up to you.
Electrically it makes no difference.
Happy Racing !
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
