help with oxygen sensor please....
Old May 26, 2012 | 11:40 AM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
I have an 84 T/A, changed the engine last fall. I'm trying to figure out where the oxygen sensor hooks up?!!? ( Not the end that goes into the exhaust manifold!!!) Any help would be apreciated!! By the way, its a 305 H.O.
Old May 27, 2012 | 01:58 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: help with oxygen sensor please....
the wiring for it ultimately heads to the passenger side firewall to go to the ECM. Some carb'd Q-jet SBC models ran the wiring under the engine but I think in 84, it's still in the harness that heads back over the back of the engine.
Old May 27, 2012 | 06:11 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
84 T/A here with CC Qjet. There should be a single black connector on a wire that goes into the harness which will then go to the ECM. The connector is on the drives side by the firewall. Can't recall the color off hand but if the connector is still on the wire, should be easy to spot.
Old May 27, 2012 | 07:30 AM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
Ok, thanks guys!!
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
