spark plug wiring need help asap!!!
Old May 31, 2012 | 09:14 PM
Bauer 904's Avatar
Transmission: a really good one.
changed my plugs but forgot what wires went to each plug. help me please. its a 1987 gta 5.7
Old May 31, 2012 | 09:24 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: spark plug wiring need help asap!!!
18436572
Old Jun 1, 2012 | 11:40 AM
Bauer 904's Avatar
Ok how do I identify the wire number and on the motor what would be plug number 1
Old Jun 1, 2012 | 01:22 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Bump the engine so the timing mark is at 0. (you can breaker bar turn the balancer bolt clockwise or grab the flywheel underneath to do it.)
The rotor is then at 1 or 6.
If it's pointing toward the drivers side front corner, assume it's 1. Clockwise from there in order like tuned perf. posted.
DS bank is 1357
PS bank is 2468
Old Jun 2, 2012 | 05:31 AM
1992COUPE's Avatar
Car: 92 RS 25TH ANNIVERSARY All original
Transmission: T5 WORLDCLASS
Axle/Gears: 3.08 OPEN
Plug number one is the left front . make sure you are on the compression stroke of the cylinder. The rotor will be pointing at number one under the cap. Put wires in firing order clockwise 18436572.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
