Firewall ground strap, and other grounds.
Old Jun 5, 2012 | 12:16 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
I have been wiring my car after my motor swap to non computer controlled carb, and as I've been wiring up my gauge senders to signal and hot, I realized something. I don't honestly remember where my grounds go. Engine block? Chassis ground? And where does the ground strap by the heater box bolt to? Also, which grounds go to the negative terminal on the battery? Thanks in advance guys.
Old Jun 11, 2012 | 03:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You’re Grounded !
You can use any ground for the gages.
One original location for the gage ground is the
black ground wires coming out of the dash connectors and going to the ‘Convenience Center’ bracket.
The Convenience Center is located behind the knee bolster.
The Convenience Center contains a flasher among other parts
(just to help you identify it).
The blower ground goes to the right side head.
The battery has 2 grounds.
The heavy cable for the main ground, and a 12 AWG body ground.
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old Jun 11, 2012 | 04:16 PM
Car: 1992 RS 6spd
Re: Firewall ground strap, and other grounds.
Thanks a whole lot man. I've been getting a bit overwhelmed with it. I did the motor, tranny, and whole interior with custom gauge cluster swap all at once. I figured id remember, but I didn't. When you say heavy cable for main ground where does that one go? I have the 12g body ground connected but not the other...
Old Jun 11, 2012 | 06:22 PM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
The big ground goes to the engine block on a bolt normally on a bracket for a/c or alternator
Old Jun 11, 2012 | 09:55 PM
Car: 1992 RS 6spd
Thanks to both of you! I honestly didn't remember and I want it to go where it's supposed to.
Old Jun 11, 2012 | 11:01 PM
Engine: LT-1
No problem.
$750 L98
Feb 1, 2025 02:25 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
mfp189
Sep 27, 2015 09:25 AM
