headlights are acting funny. Trans Am
Old Jun 19, 2012 | 09:44 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
Ok, not my headlights are acting funny. When I push the switch to turn them on they wont go up but the lights come on HOWEVER if I push the switch and hold it in the midway position before it locks into position the motors come on and push the light up. Also, I have one headlight that moves fast then other. Anyone know what could be causing these problems???
Old Jun 20, 2012 | 12:11 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: headlights are acting funny. Trans Am
The bushings inside the gear of the headlight actuator are bad. Many sources exist for aftermarket replacement bushings made of Delrin. I too make a kit that repairs this problem. TDS 209280 deluxe headlight repair kit, $20.25. The kit contains 6 CNC machined Delrin bushings, two side-cover gaskets, one motor gasket, two screws & nuts (often the screws that hold on the motor to the actuator houaing snap off their heads), a packet of synthetic grease and a detailed instruction sheet. If this is the first time the repair has ben made, the bushings are what you'll need, since that was the weak-link in the headlight actuator system. If a repair was already made previusly, then you may need a gear.
http://www.top-downsolutions.com/Bod...ght-repair-kit
Lon Salgren
Old Jun 20, 2012 | 08:59 PM
But would this cause both headlights to function like this even when I can hold the switch is a just before being locked postion?
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
