installing a toggle switch??
Old Jun 20, 2012 | 10:44 AM
napalm368's Avatar
Car: 1986 iroc z28
Transmission: 700-r4
HI. i have a 1986 iroc. and i have some LED lights that i want to work off of a toggle switch. i watched a vid on how to use a fuse tap..but dont know where i can plug the fuse tap in on the fuse box. i do have some empty slots ,,but im not sure if it is safe to plug into any of those,,thats why im asking. i dont know too much about wiring.just very basic knowledge.thanks for any replies at all....ps...and what size fuse would be recommended for the fuse tap? 10 amp? 15? 20? does it matter?
Old Jun 20, 2012 | 06:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: installing a toggle switch??
Originally Posted by napalm368
10 amp? 15? 20?
does it matter?
A wire of a certain size ( gauge ) is rated to carry a set amount of current so fuse must be lower than that amount
so it blow first and protects the circuit ( the whole reason for a fuse )
A 30A fuse on a wire rated for 10A means the wire will burn out ( and possibly your car with in ) before the fuse will ever blow
So fuse choice is based on wire size which is based on how much load is on that circuit.
If you run a motor that draws 10A on wiring that is rated at 3A then you will also problems
Old Jun 25, 2012 | 05:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LED Sled
The average LED draws a hundredth of an amp therefore unless you’re using a huge quantity, use the BAT terminal on the fuse block.
The BAT terminal is protected with a 20 amp fuse already in your car.
If you’re using fine wire for the hookup you can install a small inline fuse for the LED line at the BAT terminal.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Caspar
Jun 19, 2016 11:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
toronto formula
Nov 10, 2015 06:17 AM
dcbsracing007
Aug 18, 2015 07:24 AM
86IROC112
Aug 17, 2015 02:00 PM
