Ignition wiring
Old Jun 21, 2012 | 03:10 PM
AlexeitheWolf's Avatar
Ignition wiring
So I was having trouble starting my car the other day and im almost certain its something to do with the ignition system. I hooked up an inline spark tester and got nothing, so i replaced the ignition coil and it still didnt help. so i tested the orange wire that goes to the BAT socket on the distributor cap and nothing popped up on the volt meter which leads me to believe its bad/broken, does anyone know where it goes or what the problem might be?
Old Jun 21, 2012 | 07:20 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Ignition wiring
How about the ignition module inside the distributor have you thought about that?
Old Jun 21, 2012 | 08:55 PM
Re: Ignition wiring
thatll be the next thing on my list to try. So far ive replaced the cap, rotor, ignition coil, tested the wire that goes to the BAT connector on the cap and got the correct voltage, i even tested the pickup coil. so it seems like the only other thing in the distributor would be the module. Does anybody know the correct impedance of the plug wire?
Old Jun 25, 2012 | 05:08 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Color Blind
Take another at that “orange wire
Any chance it might be
pink ?
Anyway if your not getting power on that wire you’re just throwing parts at the car, with the usual zero results.
You have a bad or burned out connection between it and the ignition switch, or power to the switch.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
