three sudden problems: antenna, horn & locks
Old Jun 24, 2012 | 08:47 PM
slym_dee's Avatar
Car: 89 Formula 350
Please forgive how this question may sound. I love my car (89 Formula 350) but i am in no way a do-it-yourself fix-it guy. After an extended stay in my garage this past winter my car awoke to three problems. The power locks aren't working, the horn isn't working and my antenna no longer goes up. Could these be related by any chance? Any thoughts as to what could have happened or what needs to be replaces.
Any and all advice is welcome and appreciated. Thanks.
Old Jun 25, 2012 | 12:54 AM
zombienerd's Avatar
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
Re: three sudden problems: antenna, horn & locks
Looking at wiring diagrams, the antenna and horn both go through the ACC fuse... Although the power locks do not appear to, it could be a common factor.
I'd check your fuses first, then relays and switches, and leave the wiring for last if all those check out.
Power locks are off the Courtesy (CTSY) fuse and the Power Accessory fuse (PWR ACC). Have you tried the switches on both doors?
If your radio turns on, then it's not the Radio fuse, but the antenna relay also takes juice from the main ACC fuse...If they're both good, your radio might not be passing the signal to raise it, the relay could have went out, or the antenna motor or wires could have gone bad. I'm not sure of the location of the relay.
The horn is fused (main ACC) and has a relay. I'm not sure of the location on the relay.
Old Jun 25, 2012 | 01:03 AM
the209bnr's Avatar
Car: 1984 Pontiac Trans Am
Engine: L69
Transmission: THM-700R4
Axle/Gears: 3.73 Posi
Check your fuse box. I had a similar issue a while back. Changed a fuse and poof problem gone
Old Jun 25, 2012 | 08:59 AM
slym_dee's Avatar
Car: 89 Formula 350
Thank you! i'll check those out today.
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
