Ignition hot wire diagram
Old Jun 27, 2012 | 02:19 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Does anyone have a wire diagram of wire that are hot only when the key is in the on position? I rewired my horn from the steering wheel to a light up toggle switch, but don't want the light draining my battery (it's wrapped around the positive terminal on the battery right now so I have to plug and unplug it.)
Old Jun 27, 2012 | 06:01 PM
zombienerd's Avatar
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
Re: Ignition hot wire diagram
If you look in your fuse box, there are a few "Blanks" to add accessories.
A few are labeled "BAT" and a few are labeled "IGN". IGN is only hot when you have the key on.
You can add accessories just by crimping a flat blade termination to the wire, and plug it in. I've got my subwoofer's remote wire running to there.
Anyway, here's a link to the best place I've found full wiring diagrams:
http://www.austinthirdgen.org/index.php?pid=19
Old Jun 27, 2012 | 09:53 PM
Dakota W.'s Avatar
Alright thanks man, I'll just use the fuse box.
Old Mar 1, 2013 | 02:27 AM
Dakota W.'s Avatar
So I recently blew a fuse when using my horn...none of my gauges worked...So it looks like I'll still need instructions on what wires are hot when they key is turned. I would be tempted to tap into my head unit's power, but I don't want to blow that up too lol.
Old Mar 5, 2013 | 06:14 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Led Sled
If you’re using an illuminated switch VIA LED, it won’t drain the battery until the Sun burns out.
If it’s an incandescent, you can tap into the
12 AWG pink wire coming out of the steering column.
Put a 10 amp fuse in line for the horn circuit as close as possible to the column.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Mar 6, 2013 | 08:49 AM
Dakota W.'s Avatar
Re: Led Sled
Happy Racing!
Alright thank you very much! Would you also happen to know a good place to tap into and what size fuse to use if I wanted to say...put LED lights in my grille?
Old Mar 7, 2013 | 04:51 PM
NINÅ's Avatar
Transmission: 765R4
☼☼☼☼☼Led Sled☼☼☼☼☼
If you want them to shut off when you turn the car off you can tap into the pink wire at the coil.
I don’t know how many LEDs you’re going to use, so use a relay.
Have the
pink wire activate the relay, and feed battery power thru the relay for the LED’s.
Also remember to use fuses.
Happy Racing!
Old Mar 7, 2013 | 07:28 PM
Dakota W.'s Avatar
I'm going to wire them up to that red switch, I'm getting a new switch for the horn. It's an LED strip that's 40 inches long(not sure how many LEDS), and I'd like to be able to turn it on when the car is off.
Old Mar 11, 2013 | 04:30 PM
NINÅ's Avatar
Transmission: 765R4
☼☼☼☼☼LED Sled☼☼☼☼☼
Not sure what you mean by the ‘red switch’ but if you figured it out cool.
If not you can use a toggle switch, to activate the relay mentioned in post #7.
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old Mar 11, 2013 | 05:13 PM
Dakota W.'s Avatar
Re: ☼☼☼☼☼LED Sled☼☼☼☼☼
Happy Racing!
oh sorry, forgot there was no picture in this thread.
This is the red switch I was referring to. I haven't had time to mess with it recently since I'm swapping an engine. I did find out that my car has everything for cruise control except the stick on the steering column though.
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
