3rd to 4th gen power windows switch swap (need wiring help)
Old Jun 27, 2012 | 11:05 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Axle/Gears: 4gen 3.23 PBR
Hi Guys,
I have swapped my door panels to 4th gen style and I don’t know how to wire power widows switches. Does anybody know or have done this.Third gen switches they are 4-wire and 4th are 5-wire.Where to start wiring.
Any help guys will be appreciated.
Old Jul 17, 2012 | 09:58 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Re: 3rd to 4th gen power windows switch swap (need wiring help)
Does anybody know or have done it.I am wondering if I should cut off wires from switch and extend them to door switch.Is there any shortcut?Let me know.
Thanks.
Old Jul 23, 2012 | 06:57 PM
eliofall's Avatar
Thanks.
I have done it in onenof my birds. On the 4gen switch there is 6 wires. One hot and one ground then two to each window. If i recall the hot and ground are the middle pins. Im at work now so i cant just take a pic of how i did it but all it is, on the third gen there is a hot and a ground going to each switch.
Over at austinthirdgen.org they have the wiring for it is you want to look at that before you try hooking it up
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
reiderz iroc
Aug 13, 2015 04:57 PM
