Battery keeps dying?
Old Jun 28, 2012 | 05:02 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
I have a 84 camaro I rebuilt. Now If I leave the battery connected over night the voltage goes from 12.8 down to 4volts. I had a aftermarket tach hooked up but I disconnected the 12v constant power from it cause I thought that was causing the problem. But its still doing that. Any siguestions?
Old Jul 1, 2012 | 10:56 PM
1984DarkHorse's Avatar
Car: 1984 Trans Am, 1989 Firebird
Engine: 305 (5.0L)
Re: Battery keeps dying?
three possible causes i have found very likely for this in all vehicles.... parasitic draw, bad battery, failing alternator.
Old Jul 2, 2012 | 07:30 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Battery Of Tests
Sometimes the under-hood or hatch light does not go out so check those easy ones first.
Then connect an ammeter in series with the battery.
If there is more than 50 milliamps there is excessive draw.
(You can use a small bulb such as a side marker bulb if you don’t have an ammeter.)
Disconnect the alternator wires to see if IT’S the problem.
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time, including the pump fuse near the battery, till you see the current drop.
That’s the circuit with the problem.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
