HEI ignition wire
Old Jul 2, 2012 | 09:35 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
HEI ignition wire
Question: If you caught your engine bay on fire and burned all the insulation off your ignition (BAT) wire, would you tape it and continue to use it, or change it ?
Old Jul 2, 2012 | 10:05 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Re: HEI ignition wire
Change it out for a new one and be done with it. Why did the engine catch fire
Old Jul 3, 2012 | 12:41 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Heh love a loaded question. Only one right answer - what do YOU think it is?
Old Jul 3, 2012 | 06:09 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
Adjusting the float levels on the Holley carb., don't know where the spark came from, didn't have fire ex. handy tried to put it out with a quilt which also caught fire---BIG MESS !
Call Me Dumb A** !
Old Jul 3, 2012 | 06:13 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
Hoping against Hope ! Might be why I'm frying ignition modules-----ya think! ?
Old Jul 3, 2012 | 06:24 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
Might as well do it right, gonna change the coil and module (matching this time),change the wires, install a 180* thermo and set the plug gap down to .040 . It's a 78 dizzy in an 84, if it still keeps killing them (module), I'll have to look at the tach as a probable cause----I don't want to loose my tach. !!
Hellbillydeluxe
Sep 22, 2015 09:58 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
