surging under load
Old Jul 5, 2012 | 11:47 PM
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
surging under load
Ok. So i'm at a lost as to what's going on. I'm having these slight surges under load. At idle, she idles perfectly. Under load its a jerky kinda feeling. I should also mention that my stereo also likes to shut it self off then turn on, and does that constantly. So I'm inclined to think the problem is linked.
As of today I replaced the battery, pos and neg cables, alternator, cap, rotor, plugs, wires and coil. These symptoms were there before I replaced these items... was hoping it was an alternator issue but wasn't. The other stuff was just due so i did it at the same time.
I'm looking for some suggestions as to where to look next.
Thanks guys
Old Aug 29, 2012 | 08:58 AM
blackfrontier's Avatar
Car: 89 GTA & 76 T/A
Engine: 5.7/455
Transmission: GTA Auto/76 T/A 4speed
Re: surging under load
I have a similar problem particularly going up a mountain pass. I just replaced the fuel pump too. Same issue. Mine starts on a dime and idles well. Once in awhile at a stop I get a brief "miss" and it is normal again
Old Aug 29, 2012 | 09:03 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Check for codes?
Old Aug 29, 2012 | 02:38 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
A slight surge under load is usually a sign of running too lean.
Old Aug 30, 2012 | 07:06 AM
Engine: 5.7/455
Mine had no codes. Don't know about his car. I have a whole thread on this issue under "stumbles up pass".
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
jrdturbo
Mar 31, 2016 02:58 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
efiguy
Sep 27, 2015 01:30 PM
