Electrical problem in my 1984 Camaro z28
Old Jul 9, 2012 | 09:12 PM
84Camarodriver's Avatar
Car: 84 camaro
Engine: 305 H.O
Hi, i ran my car today and i went to turn the dial to turn on the guage cluster backlighting and i heard a small click, and now they wont work nither will the side markers or rear lights, my head lights and hi beams and brake lights work though......
Old Jul 16, 2012 | 04:28 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Switch In The Ditch
First check the TAIL fuse.
If that’s OK use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the orange wire at the switch.
Is there power there?
If yes probe the
brown wire on the switch when the switch is in the on position.
Happy Racing!
I’ll Bump You Once To Move You Over, Next Time I’ll Spin You
84z96L31vortec
Aug 20, 2017 12:16 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
