Fuel guage acting GOOFY!
Old Jul 17, 2012 | 05:42 PM
Blue1990camaro's Avatar
ok its an 87 Sport Coupe 2.8L auto
for a while i thought it was just stuck like this but i took a sharp turn last night and it went to 3/4 tank then back to way past full, i dont think it has more then 2 gallons in the tank tho...... its been lik that since i bought it, anything that could cause this or a how to fix or what to check????
Old Jul 20, 2012 | 10:05 AM
Re: Fuel guage acting GOOFY!
anyone??? i thought it was teh fuel sending unit but if that was bad wouldnt the gauge never move??
Old Jul 23, 2012 | 01:47 PM
hello??
Old Jul 23, 2012 | 02:28 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Mine does the same... Ive traced all the wires except where they go thru the rear hump into the tank.. So at least in my case, maybe yours, the sending unit is bad or a loose connection. IIRC full tank means no ground. But dont hold me to that..
Old Jul 23, 2012 | 05:19 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Goofy Gas
Here’s how to check the sender:
Remove the sender wire going to the gage.
Connect an ohmmeter between ground to that wire.
A correct reading will be between zero and 90 ohms.
With 2 gallons in the tank the reading should be much closer to 0 ohms.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Jul 23, 2012 | 07:06 PM
alrite ill check it with my ohm metter tomorow if i have time
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
355sbcTPI
Aug 19, 2015 04:38 PM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
