alternator gauge
Old Jul 18, 2012 | 10:26 PM
bigbadrat's Avatar
alternator gauge
ok here is the problem.on my 92Z28,alternator gauge shows it charging,but when i kick on the ac,the gauge drops.it falls to 10 volts.if i drive like this too long,the battery drains down to the point stalling the car.i have checked and replaced the alt.no change in that.was told the compressor clutch coil was bad,replaced the whole compressor.still not fixed.was told today that the fuseable link could be bad so i did the jumper wire off the back of alt to battery,no change.so now i am lost with this.it all worked fine last year and this year the weather is too damn hot.i need help.anybody have this issue before?
Old Jul 19, 2012 | 08:26 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: alternator gauge
I have two words for you[check grounds] every ground you see will need to taken apart and cleaned and scraped and put back together. Examples would be ground to chassis ground to motor ground to body ground to firewall. A lot a people forget the grounds.
Old Jul 19, 2012 | 08:51 AM
bigbadrat's Avatar
I WAS THINKING GROUNDS BUT WITH IT ALL WORKING FINE TILL I HIT THE AC IS WHAT HAS ME PUZZLED.I WILL TRY AND LOOK AT THEM TONIGHT.
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
apie2546
Sep 24, 2015 12:27 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
