electric dual fan swap issues
Old Jul 28, 2012 | 12:33 PM
snake70's Avatar
Car: 1979ta, 1981 formula
Engine: 400 sbc 403 olds
Transmission: th350 th400
Axle/Gears: 308 373
Hey guys i am swapping a dual fan setup from a 89 gta to a car that had a clutch fan. I will be running a 411 pcm from a van on this wierd intake i have.( think tpi meets tunnel ram) well my issue is this the van had a clutch fan and i want this electric setup and don't want a toggle switch and want them to work properly how do i go about setting this up.
Old Jul 28, 2012 | 12:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: electric dual fan swap issues
Use a fan controller.
Old Jul 28, 2012 | 01:08 PM
snake70's Avatar
Axle/Gears: 308 373
Whats that? Explain.
Old Jul 28, 2012 | 01:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
there are different kits available but something like this.
http://www.jegs.com/i/Derale/259/16759/10002/-1
Old Jul 28, 2012 | 02:15 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Why not run one from the stock style temp switch in the cylinder head and the second from an adjustable controller like above. Set one to run primary at lower temps and the second to come on at a higher.
Old Jul 28, 2012 | 02:58 PM
snake70's Avatar
Axle/Gears: 308 373
Stock style is what i would like, you say temp sensor to the head? Ok im guessing that goes to a relay. Then to power. How does the stock style turn on at high temp?
Old Jul 28, 2012 | 03:05 PM
Engine: Lb9
Transmission: M20
the coolant temp sensor grounds the relay at the specified temps. hypertech makes lower turn on temp sensors. or gp sorensen.
FS6 - Closes at 204*-220* F
FS4 - Closes at 211*-227* F
FS1 - Closes at 222*-238* F
Old Jul 28, 2012 | 03:17 PM
snake70's Avatar
Axle/Gears: 308 373
This looks perfect. Just what i needed thanks
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
