Adding an LED to a relay?
Old Jul 31, 2012 | 07:08 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
I got a variable coolant temp switch for my secondary fan. It comes with a relay. The relay works differently than I am used to. Instead of activating the positive leg of the fan, it activates through the negative leg. So the fan positive is wired directly to the battery. The fan negative goes to the red input wire on the relay. Coming out of the relay is a black wire to ground. I want to add an LED in the cockpit so I can tell when the fan has been activated. Would I wire the positive side of the LED to the negative black wire coming out of the relay and the other side to ground?
Old Jul 31, 2012 | 07:33 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Adding an LED to a relay?
No. Wire the pos side of the LED (anode) to 12V, and the neg side (cathode) to the fan negative. Ie, paralleled across the fan. Don't forget a current limit resistor.
Note- if it's just a relay output, you should be able to put it (relay contacts) in either the pos or neg fan wire as you wish, it's just a set of contacts.
Last edited by TreeFiddy; Jul 31, 2012 at 07:35 AM. Reason: Couldn't get brain together on last line
Old Jul 31, 2012 | 08:48 AM
Car: 1988 GTA
Engine: 400 CI
Thanks Tree! I'll go test that now. It also has an override connection you can either wire to the AC positive or a switched 12v source. That is why I was afraid to alter the instructions. I'm used to everything working off ground.
Thanks again.
Old Jul 31, 2012 | 06:07 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
your battery should be between 12 and 14v, most red leds are rated around 2.2v at 20ma... so you would need a resistor value of about 500-600 ohms rated at 1/2w ......
Old Jul 31, 2012 | 06:38 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i would wire to a switched 12v source since you'll only need it when the car is running...
Old Jul 31, 2012 | 08:45 PM
Car: 1988 GTA
Engine: 400 CI
I used one of the Radio Shack 12v LED which already have the resister built in.
Old Jul 31, 2012 | 08:46 PM
Car: 1988 GTA
Engine: 400 CI
Thanks Will. It is wired to a switched source. Wouldn't want to chance the fan coming on while I'm working on the car.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
