90 Speedo Whine/Buzz
Old Aug 1, 2012 | 02:25 AM
Mr.Franco's Avatar
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
Hello...So I swapped my 110 speedo gauge into a 145 housing because everything but the speedo was off/not working on the original 110 mph cluster. Now my 110 speedo (original) is about 20mph off (too low) and there is a buzzing/whining noise coming from the speedo.
BTW: When I swapped the speedo, I also kept the board that it attaches to.
Any thoughts?
Old Aug 1, 2012 | 07:20 PM
Mr.Franco's Avatar
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
Re: 90 Speedo Whine/Buzz
(crickets) I guess this was a good question? I must have stumpped the masses
Old Aug 1, 2012 | 08:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds more like a mechanical speedo issue (82-89) than an electronic (90-92).
JamesC
Old Aug 2, 2012 | 01:24 AM
Mr.Franco's Avatar
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
Nope...it's a 90-92 speedo.
Does putting a 110mph speedo in a housing that originally held a 145mph speedo make a difference? Can this be the issue?
Old Aug 3, 2012 | 12:17 AM
Mr.Franco's Avatar
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
Figured it out: The needle needed to be adjusted. It must have gotten moved when I removed/installed the speedo.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
