Brake light switch question
Old Aug 12, 2012 | 11:59 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
I am custom wiring my entire car. I am using the factory brake light switch. It has two spade connector tabs on it and what looks like a hose nipple. I hooked a keyed positive to one connector and the brake harness wire to the other. Now I assumed with the switch button pressed in. The lights would be off. This would be simulating my foot off the brake pedal. However with the switch button pressed in. The lights come on. With it released they turn off. Am I missing something here? It should be the opposite.
Old Aug 13, 2012 | 01:36 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Brake light switch question
That brake switch with the hose nipple is for cruise control. It has the opposite sense to the correct brake light switch - is closed with the brakes off, which isn't what you want.
Old Aug 13, 2012 | 08:33 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
So I need something else. What should I look for?
Old Aug 13, 2012 | 10:28 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Ok I ordered this one. Hopefully it operates the way I need it too.
http://www.painlesswiring.com/webcat...rchField=80172
Old Aug 13, 2012 | 11:36 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The car should have had both from the factory, ie two switches side by side. If the original brake light switch is gone, a generic parts store one like you listed should work fine. They are usually nc I've found.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
