Two (dumb) general wiring questions
Old Aug 16, 2012 | 08:35 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I'm in the final stages of converting my engine & ECM, only have a few more components to get wired up. I have two probably dumb general questions:
1) When doing auto wiring of components that require both a constant and switched (ignition) 12V power supply, do both of the power wires need to be fused or just the constant? For example, I'm wiring up a cooling fan and I know I need to fuse the main power line but does the line coming from the ignition need a fuse, too?
2) Is there a preferred location or method for tying into an ignition wire? I can easily get to the one that goes to the coil, but I'm not sure if it's okay to split that off into 2 or 3 for others that I need. I thought about using that wire to run to a small fuse block and then distribute the ignition power from there, but then I'd have fuses for them (which goes along with my question above). I know they make junction boxes or studs for either positive or negative from the battery, can one of those be used for ignition or does it cut the power down too much?
Thanks in advance.
Old Aug 16, 2012 | 05:02 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
3.…..2.…..1.…..We Have Ignition
The ignition wire as it comes from the factory is protected with a fusible link.
You shouldn’t be feeding the fan from the ignition.
But you can energize a relay from the ignition, and have the relay feed the fan from the battery.
It’s OK to connect near the coil because you should just be going to relay coils.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Aug 16, 2012 | 05:12 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Re: Two (dumb) general wiring questions
Yes, sorry, that is correct - I'm not feeding the fan directly but rather a relay.
I was just wondering in general what the proper procedure is for tying 2 or 3 other devices - say, LED lights or something - into the ignition wire. If I tap into the ignition wire feeding the coil, is that going to negatively affect anything?
Old Aug 16, 2012 | 05:37 PM
NINÅ's Avatar
Transmission: 765R4
Not unless you draw a lot of current.
And no one will be able to give you a number such as X amps is OK, but X+1 is too much.
LEDs don’t draw much, relay coils don’t draw much.
But let’s say you wanted to energize a lot of relays.
No problem.
The way to do that would be to use one relay, and have that relay supply power VIA the battery to all the other relays.
Happy Racing!
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
