How to wire to a fused 12V source?
Old Aug 18, 2012 | 10:48 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
I need to figure out how to wire something to a fused 12V source. It needs 12V constantly. Would I connect a fuse and a wire at the fuse block? I don't know much about electrical and could use some help.
Old Aug 18, 2012 | 10:55 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: How to wire to a fused 12V source?
What are you wiring? How much amperage is it going to draw?
Old Aug 18, 2012 | 11:26 PM
Gsoleski's Avatar
Car: 1984 Z28
I'm wiring the converter to lockup with a toggle. A few different sites say to use a 10 amp fuse and coonect it to the fuse box somehow
Old Aug 18, 2012 | 11:50 PM
Impaqt's Avatar
Most cars have a spare fuse or aux connection available to use for this. Not sure whats confusing you.
But so you know, thats not whats normally referred to as a "Constant" 12v termination. You actually would not want that constant. You want the circuit to only be live when the car is actually running then have the Manual toggle from there.
Old Aug 19, 2012 | 02:17 PM
Gsoleski's Avatar
Car: 1984 Z28
I guess my question is this...I have the wire that needs power, a fuse, and the fuse block. Does the wire connect at the backside of the fuse box? then just plug the fuse in like normal?
Old Aug 20, 2012 | 06:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuse Ruse
Yes that’s the correct way, and put the new fuse as close to the fuse block as possible.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
apie2546
Aug 8, 2015 07:12 AM
