Megashifter - Wiring neutral safety switch
Old Aug 19, 2012 | 10:41 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
91 z28. when wiring my neutral safety switch up with a mega shifter the instructions say that some vehicles have 2 additional wires that tell the ecm that its in park/neutral, and to wire these up with the switch an additional relay is needed. i understand how the relay would work in this situation, but it seems at tho i can just tap the ecm side of these 2 wires into the wire that is closed of the neutral safety switch. the neutral safety switch puts out a ground signal, and the ecm receives a ground signal when in park/neutral, so i should be able to do this. am i missing something to where i should not do this?
Old Aug 19, 2012 | 11:42 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Megashifter - Wiring neutral safety switch
You are right, technically it is the same function (grounded switch in Neutral or Park).
The only difference I can see is that the starting circuit is not always grounde but can have power on it (when cranking) and also flyback spikes from the solenoid.
For that reason, I would not recommend using the starting circuit for the ECM input.
I would strongly recommend using the relay.
Hope this helps.
Lou
Old Aug 23, 2012 | 01:50 AM
QuickStyle's Avatar
Car: 91 Z28
after running over my wiring diagrams again, you are absolutely right, i totally forgot about the starter running thru the wires. thanks for clearing that up for me, i'm going to run the relay. thanks.
Old Aug 27, 2012 | 03:10 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
when I did mine before I just connected the thick yellow and purple wires together and it worked as the loop it completed like it would be on a stock shifter
Old Aug 27, 2012 | 04:58 PM
QuickStyle's Avatar
Car: 91 Z28
but that would let it start in any gear, i'd rather have a relay to prevent that.
Old Aug 27, 2012 | 05:44 PM
BigBadLou's Avatar
Engine: TPI
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
overdriv
Aug 20, 2015 03:52 PM
355sbcTPI
Aug 19, 2015 04:38 PM
