starter or bad wiring?
Old Aug 24, 2012 | 08:13 PM
dstack18's Avatar
okay so my starter sometime grinds my flywheel ... at first it would just make a lilttle extra churping after start but then it would grind until you shut te engine off but this however is totally random ... but today i started the car after two months of sitting (had to jump it ) and no grinding what so ever .... but another strange thing ... if you have the key removed and the car off you can hit the starter and it will try to turn over ... whats my problem here?
Old Aug 24, 2012 | 08:27 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: starter or bad wiring?
Starter may need shim(s).
Starting without the key-- you need a new ignition switch. Sounds like the current one is broke
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Tonyy_z
Aug 12, 2015 07:20 AM
milk
Aug 10, 2015 06:26 PM
