Passenger Power Widow Toast
Guest
Posts: n/a
My passenger side power window is dead. If I don't touch the switch for about two days, the window might, MIGHT, go down a half inch. I'm thinking new motor? The switch is good, I checked. Could it be the regulator? While I'm in there replacing the motor or regulator I will grease and lube everything. And another big question: How in the HELL do I remove the door panel to get to the motor?
Car: 1984 T/A
Engine: LQ4
Re: Passenger Power Widow Toast
im having the same issue. to get to the window motor and regulator you need to take off the armrest, cupholder (if you have one), and power locks. I have a bird but the armrests and power lock moulding have torx head screws.once those are off. you can use a flathead/spatula...watever to pop the door panel off.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
sailtexas186548
Aug 24, 2015 10:11 PM
