1982 lights
Old Aug 27, 2012 | 09:42 PM
outridger's Avatar
1982 lights
ok i could use a little help, ive got a 1940 Chevy that ive pulled the harness from a 1982 firebird. my problem is i have no lights (tail lights, brake, turn, headlights) . I've found the my red wire that supplies power to that row in the in the fuse panel. If i supply it with power with a jumped then everything works fine. So i would like to know if that wire should connect to wire alternator wire or should it be tied into the battery. I think it should good to the battery so that i would have lights when the key is off. thanks guys
Old Aug 28, 2012 | 02:22 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: 1982 lights
I would think that that wire would run to the starter and get full time power there thru a fuseable link.
Old Aug 29, 2012 | 09:36 AM
outridger's Avatar
Re: 1982 lights
fastgm.com/wiring this is a great place for wiring 82-92. shows location and what the plug looks like if you look at the pdf in one of the folders
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
