The motor wont draw my hatch down.
Old Sep 1, 2012 | 01:30 PM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
I took everything apart, replaced the solenoid and cant figure out the problem. Anyone know about these things or what might be the problem?
Old Sep 4, 2012 | 04:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hatch Latch
If the unit raises but won’t pull down take a look at the two switches in the unit.
One is moved when the hook presses on it.
The other one is a small round one with a spring near it with a tab.
It rotates as the motor operates.
Make sure both function.
The small round one can fall out.
Happy Racing!
If My Engine Has An Illegal Part, And The Inspector Doesn’t Hear It, Does It Make A Sound?
Old Sep 6, 2012 | 12:45 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: The motor wont draw my hatch down.
https://www.thirdgen.org/tech/hatchpulldown.pdf
This Tech Article I wrote will help you doagnose and repair the hatch pull down unit.
Lon
Old Sep 13, 2012 | 10:06 AM
Engine: 5.0 L03 V8
Thanks Lon that was a helpful link. I found out I have a cracked motor housing (my friend slammed my trunk because they didn't know it was automatic). It doesnt make sense that the piece that takes the most stress is made of plastic. If I can find a reinforced TDS motor housing I'd like to buy one.
Old Sep 13, 2012 | 11:13 AM
lonsal's Avatar
http://www.top-downsolutions.com/hat...pull-down-unit
Finding it is pretty easy. But it IS on page two of the hatdh repair items on my web site.
Lon
Old Sep 13, 2012 | 03:15 PM
Engine: 5.0 L03 V8
oh wow, I appreciate it man that's exactly what I need
LittleFranks
Sep 17, 2015 12:22 PM
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
