charging issues
Old Sep 8, 2012 | 06:01 AM
STWB's Avatar
charging issues
I have been having problems with my car not want to charge the battery. When you put a charger on it over night then start it up it'll read at 13 on dash v-meter. But as soon as you turn on headlights or fan,heater ect it drops to just above the dead line. I checked my battery connections and the alt. Looks fairly new. Any ideas for a checklist?thanks.
Old Sep 8, 2012 | 07:35 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: charging issues
You might need a new alternator. IMO I would take it off and have it tested at one of your parts stores.
Old Sep 8, 2012 | 07:38 AM
STWB's Avatar
Re: charging issues
I've got an extra one that came with the car when I got it, I'm going to stop by and have it tested today. Will update if that one is good and fixes the problem.
Old Sep 8, 2012 | 09:01 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: charging issues
You can take it to a parts store and have them test both the ALT and the Battery or you can do a back yard test and determine if the ALT is somewhat good..
If you perfer the backyard mechanics test, Start the car, carefully remove the - off the battery terminal. The car should stay running.. If it continues to run, turn on the headlights, and the defoster and heater.. The Alt should have enough power to keep the car running with everything on. Then reconnect the - terminal back on the battery.. That would tell me the Alt is good but the battery might be bad.. So then remove the battery and have it load tested...
Old Sep 8, 2012 | 09:06 AM
Edwardgp's Avatar
Engine: 454-350
Re: charging issues
Be sure and update.
Old Sep 8, 2012 | 07:12 PM
STWB's Avatar
Re: charging issues
So i'm guessing that i need a new battery. it passed the no ground while running test. the alt that came with it was only putting out 8 volts when tested, so its going on the scrap pile. Thanks for the ideas.
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
Slush92RS
Sep 2, 2015 08:56 PM
